We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
On my non-Meraki FWs, I've always been able to toggle certain rules on/off, as needed. I'm not seeing the option on the MX105. Does that option exist, and if so, where? Maybe I'm overlooking it...
Solved! Go to solution.
Unfortunately you cant.
You could move rules under a more global rule that would allow traffic.(below a allow any any)
Or you could use api to get and put to speed things up.
It does seem such an obvious feature, doesn't it?
Just like having definitive/absolute line numbers for rules 🙂
