I'm not sure what I'm doing wrong with this. We have a department that is getting their own internet connection, so will have their own MX device (MX64W) with their own VLAN (104) in their location. However, they also need access to the internal servers on VLAN 68 which is on a MS425.
MX64W (.104.1) - LAN3 Trunk port allow 104 - MS425 has VLAN 104 - (.104.2) and VLAN 68 (.68.1)
I can ping from a device on VLAN 104 on the MX64W to the VLAN 68 and webpages hosted on 68 work. I know the routing works.
However...anything blocked in our Layer7 rules (it's a lot! slow internet with lots of users...) is also blocked on this static route. Joining the AD domain and smb file server doesn't work. The event logs on the MX64W tell me it's blocked. If I remove the rule, then things work, but that also allows it from internet as well.
How can I tell the MX64W to treat these static routes as internal LAN, and not firewalled?
