Disable 2.4GHz on Z3
KarstenI
Hi all,
is anyone aware if there is a way to disable the 2.4GHz band on the Z3?
Have a great day, Karsten
Not sure. This indicates that you could try ask support.
https://community.meraki.com/t5/Security-SD-WAN/Z3-WiFi-Configuration/m-p/51919
KarstenI
Damn, why didn't I find that post ...
KarstenI
Just some feedback on this. Support was on it for two weeks, but all taken actions didn't help. 2.4 stayed active. Now the support is sure that it is no longer possible. I added a wish to bring back this feature just to be a good RF-citizen.
