Diffie Helman 20 in MX.
Delphino
We are configuring a VPN with a non Meraki Peer. Te other side works with DH20. MX doesn't support this. A suggestion of another product?
As you noticed, MX does not support DH20, so your options are to change the DH on the other side or replace the MX with another firewall, such as a Palo Alto for example.
Another option I see would be to set up a Linux VM on the side with the MX and configure the VPN tunnel on that Linux machine and route through it.
A virtual Cisco ASA.  The most common one I used is the ASAv10.  Run it behind or beside your MX.
https://www.cisco.com/c/en/us/products/collateral/security/adaptive-security-virtual-appliance-asav/...
GIdenJoe
Either have the other side change their DH parameter to DH14 or have a separate router device do the VPN and just route to it from the MX.
