DNS Issues
Cozzycam
DNS Issues
Hi all,
Got my Meraki switch, AP and Router set up & have been using it for a good year with no issues! Great fun to play with! I have the Router plugged into my ISP (EE) router as a modem.
There was circuit maintenance the other day & since, I've had to manually configure DNS servers on the endpoints to 1.1.1.1/1.0.0.1 for them to work, otherwise, it fails to find DNS. can ping IPs but not domain names.
The router is configured to point to the EE router for DNS. The Switch and AP are pointing to the Meraki router, but are both reporting "DNS is Misconfigured" error.
Have turned the WiFi back on the EE router for testing & devices connected directly to the EE WiFi can find DNS with no configuration required.
I have also tried putting the EE Router in as Primary DNS for the Meraki Switch & AP, but still, no luck getting it to work.
Any ideas you lovely people?
TIA!
Configure static DNS on the MX to point to either the same settings that are on the EE router or a public DNS such as 1.1.1.1 it should then hand that out to clients via dhcp.
Perhaps the EE router has had an update that is stopping the MX get DNS settings from it.
Cozzycam
Thanks mate! That's done it!
Tried everything but that solution it would seem!
Really appreciate the help there.
No problem, I had to do the same with a BT hub...
