- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
DMZ on multiple uplinks for failover
Hi all,
We have created a DMZ on a Meraki MX85, by setting the public static block as a separate VLAN and then adding 1:1 NAT rules to allow remote connections on this VLAN.
There are servers on this VLAN with public IP addresses configured, and with the current setup they are reachable remotely.
The site also has a secondary WAN for Failover, however on the 1:1 NAT you can only specify a single uplink. The ISP has routing in place that will forward the public subnet down to the secondary link in a case where the primary has failed, however the 1:1 NAT rules only allows you to apply them to a single uplink.
Is there any way to set it so it will apply to the secondary in a case of failed primary link? Or is there a better way to set this up?
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Where does it stop you doing the mapping on the second WAN, I can save this config below:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's when trying to apply the same 1:1 NAT on both Primary and Secondary.
So using the same Public IP on both rules, it does not allow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I can see why that wouldn't work, as 1:1 NAT works both ways, the firewall wouldn't know what the next hop was for outbound traffic from the internal IP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That makes sense.
Do you perhaps know of a different way to set it up that would work?
I have looked into the NAT exception feature which can work because you can disable NAT on both uplinks, my issue with that though is the customer then loses the Client VPN functionality and can't reach the other VLAN remotely
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Indeed. In not sure you can do this just with a single MX instance. @DarrenOC how would you approach this?
