DHCP relay for VPN clients
MichaelMurray
Is there a way to relay DHCP requests to a server for VPN clients? Or does the MX have to hand out these IPs. My big problem is that the MX doesn't allow you to append a FQDN suffix to DNS lookups.
2 Replies 2
It has to hand them out.
If this is for a Windows machine and you create the connection using Powershell you can configure this using the DNSSuffix option.
http://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
JKatSmith
This worked great thanks.
1 note.  if there are any values in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
which might have been left from some other prior administrator you'll want to delete the SearchList
Otherwise that seems to take priority.
