I am running a WISP and running private IPs on all my network and getting DHCP IP conflict on daily basis. Is there is anything possible to stop receiving the conflicts. In Cisco there is an option called DHCP snoping is there anything related to this available in Meraki?
Depends on the use case really. You can fire up a SSID that runs NAT mode, where the AP will handle the IP addressing for connecting clients then NAT that connection,
Or if the problem is with multiple DHCP servers and you have Meraki switching, you can use the DHCP Snooping feature here to restrict the DHCP servers that connecting clients will accept offers from:
What might be easier, is (using Meraki DHCP) give each machine a static reservation. Then the IP addresses will never change and hopefully it will make things more stable.
Otherwise as @Spectre says, you need a Meraki switch.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3960f63e4bd7b6","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3960f63e4bd7b6_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3960f63e4bd7b6_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3960f63e4bd7b6_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3960f634e55de4","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
