DHCP Problems
AlexanderDrago
DHCP Problems
Hello!
I have some question about this error - meraki extra: no_offers_received
And about best practice for DHCP. We have 2055 clients on MX250 DHCP
Because we have some issue that DHCP on MX is stopping work correctly, a lot of DHCP requests and maybe it provides a lot of queues for receiving IPaddress
Is VLANs can resolve this problem?
And Meraki has 1 DHCP system daemon and work from others configuration or when we create new DHCP it's creating new DHCP system daemon and work from his config file?
Thank you
Have you exhausted your DHCP scope?
How are the clients attached?  One single wired VLAN with everyone in it?  A VLAN with APs and uses WiFi attached?
Sorry for a long answer
No, we didn't exhaust DHCP Scope
I didn't understand about client's attached question. No, we use different VLANs. Yes, we use some Vlans for WiFi
Charlie-Sangha
Seen this in the event logs before:
Recommend this Meraki Troubleshooting link: https://documentation.meraki.com/MR/Monitoring_and_Reporting/DHCP_%22no_offers_received%22_Errors_in...
Just check the following:
  • Is the DHCP configured correct.
  • Is there sufficient pool of IP addressing
  • and do the clients have connectivity to the DHCP server.
Hopefully that helps.
