Could Catalyst 9404 Series to be Monitored on Meraki Dashboard?
meraki-newbie
Dear meraki Community,
I want to deploy Catalyst 9404 as Core Switch by connecting itu MX250, Could Catalyst 9404 Series to be Monitored on Meraki Dashboard?
Thank you
GreenMan
Meraki Alumni (Retired)
Catalyst 9400 switches cannot be monitored in the Meraki Dashboard just now.   It's likely to come in the future, but I'm not aware of a specific time-frame for that
meraki-newbie
hopefully Catalyst 9400 could be monitored from Meraki Dashboard, like another Catalyst 9200/9300/9500 families.. this will be another breakthrough.
KarstenI
In a CL discussion last year, they said that the chassis approach is not well representable in the way the dashboard is built. They compared it to the early days when IPv6 was the same problem but was adopted over time.
GIdenJoe
I believe because of the special architecture of chassis based switches it is more difficult to get it into the dashboard.  So they could potentially come to dashboard but they will take the longest.
