Sooo after working with Meraki be aware if you are working on implementing Content filtering you really need your VLAN Interfaces on the MX and not the Layer 3 Core switches. I had my interfaces there to help with just dedicating the MX to Firewall duties only. The problem is when you are trying to look for content filter logs it will report back as the switch not the specific client. Only way Meraki informed me to fix it was moving VLANs to the MX, which does appear to have worked.
But the follow up problem now that I am seeing. So, does content filter with Meraki only show when something is actually blocked? Doesn't actually show when there is approved URLs passing through the MX only showing the blocked content. Even if I have the filter set to "All Filtering".
Anyone else have the first reported issue?
And second paragraph issue a common thing?
