Content Filtering white list
Matt_C
Hi all,
Does the white list allow the URL to be visited if that URL is covered by a Content Category defined in the Category blocking section of content filtering, also does it allow a URL to be accessed if it is in the black list?
Manythanks for your time and help.
Kind regards
Matt
RaphaelL
Hi ,
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Content_Filtering
If any of the above steps produces a match, then the request will be blocked or allow listed as appropriate. The allow list always takes precedence over the blocklist, so a request that matches both lists will be allowed. If there is no match, the request is subject to the category filtering settings above.
I would supose that it also takes precedence over the Content categories & Threat categories
Hope that helps !
Matt_C
Hi there,
Many thanks for the reply, yes it looks like the white list trumps the black list and the content categories if I have understood the document correctly.
Many thanks for your time and help
Allow List
Applies the following settings to a client:
  • Restricted Youtube content will NOT be bypassed by allow listed clients as it is NOT considered part of Content Filtering.
  • IDS/IPS under Security & SD-WAN > Configure > Threat Protection will NOT be bypassed.
Note: The device is still subject to association requirements and per-SSID bandwidth limits on MR access points, as well as Uplink Configuration and Security Filtering on a MX security appliances. RADIUS attributes that would assign a bandwidth limit to a client
