Content Filtering - Report By Category
We are looking for ways to create reports based on clients that visit URLs that are under categories that are blocked.
For example, the summary report tells you how many hits there is on a specific category (Top Blocked Sites by Category) but you cannot se what clients actually visit those sites.
Is there a way to get this information other than checking the event log for Filtering Events?
6 REPLIES 6
Re: Content Filtering - Report By Category
@diego_ers  There is possibly some way of doing this but it would most likely involve an API and syslog. I am sure someone whos familiar with the Meraki API will be able to answer this.
The event log is the way to go.  You can also use the "Download As" option to get it into a CSV if you want to do further processing.
Can we get the entire log without having to page through?
Negative.  You have to page through,
Thanks! syslog it is
If you have a SIEM solution implemented you can pull this in through Syslog
