Content Filtering Powered By Cisco Talos on MX68CW
Brogan
Good Day - I have a few MX68CW with Advanced Licensing and not able to see Content Blocking page. Is Content Blocking supported on MX68CW?
5 Replies 5
Do you have administrator permissions? The license has already been added to the dashboard.
Brogan
Yes and Yes
In this case, I suggest you open a support case once It's supported on MX68cw.
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX67_and_MX68_Datasheet#:~:text=....
Are you saying you can't see the "Content Filtering" page where you configure what to block?
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Content_Filtering
Mark1337
Meraki Alumni (Retired)
Hi There @Brogan,
I noticed you had a case open with us on July 11th, have you been able to get the solution you were looking for?
I see from my side your device is reporting to have "Content Filtering" for the device in question.
Just wanted to check in to see if you needed any other assistance!
Thanks,
Mark
