- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Content Filtering Message?
I could have sworn that when I enabled Content Filtering on my MX84, blocking adult sites for example, that when you tried to go to them, it would give you a message about 'this has been blocked for XYZ reasons' or something.
I just upgraded to 14.39 and testing is showing it basically just not loading the page, and eventually an error page message.
It works in the sense that I can't reach it, but just thought it would give a message.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I also found this page, not sure if it helps you or not but at the bottom is a couple of troubleshooting points for the 'Block Page' not displaying
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
My 14.39 MX64 still has the Block Message configuration under Network-wide General. Do you have a message set there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Maybe i'm just not remembering it correctly? i just could have sworn there was a message about content filtering.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It is? Oh, well ignore me then. I always assumed that was for content filtering.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I get the following, I cant see that you can customise it anywhere or turn if off/on ? It points to Wired.Meraki.com though
So maybe with @jdsilva's first reply make sure the first part is enabled (from the screenshot)
"Local device status pages (my.meraki.com, switch.meraki.com, wired.meraki.com)"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Haydn wrote:I get the following, I cant see that you can customise it anywhere or turn if off/on ? It points to Wired.Meraki.com though
This is what I believe I remember seeing in the past.
Hmm...I guess I'll have to tshoot this =(
Thanks !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I guess I need to find a page not using HTTPS
Block Page is Not Displayed
If your browser/the website is using HTTPS/SSL, the browser will not be forwarded to the block page. Due to the encrypted nature of SSL requests, the MX cannot decrypt and redirect HTTPS traffic. Instead, the MX will force the request to timeout (an example of which can bee seen in Fig. 3, below).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@NolanHerring Yes HTTP will show a block page, HTTPS wont so you normally get a server error/timed out message.
The is normal will most vendors unless you are using some form of DPI-SSL / MITM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
