I could have sworn that when I enabled Content Filtering on my MX84, blocking adult sites for example, that when you tried to go to them, it would give you a message about 'this has been blocked for XYZ reasons' or something.
I just upgraded to 14.39 and testing is showing it basically just not loading the page, and eventually an error page message.
It works in the sense that I can't reach it, but just thought it would give a message.
Solved! Go to solution.
I also found this page, not sure if it helps you or not but at the bottom is a couple of troubleshooting points for the 'Block Page' not displaying
My 14.39 MX64 still has the Block Message configuration under Network-wide General. Do you have a message set there?
It is? Oh, well ignore me then. I always assumed that was for content filtering.
I get the following, I cant see that you can customise it anywhere or turn if off/on ? It points to Wired.Meraki.com though
So maybe with @jdsilva's first reply make sure the first part is enabled (from the screenshot)
"Local device status pages (my.meraki.com, switch.meraki.com, wired.meraki.com)"
@Haydn wrote:I get the following, I cant see that you can customise it anywhere or turn if off/on ? It points to Wired.Meraki.com though
This is what I believe I remember seeing in the past.
Hmm...I guess I'll have to tshoot this =(
Thanks !
@NolanHerring Yes HTTP will show a block page, HTTPS wont so you normally get a server error/timed out message.
The is normal will most vendors unless you are using some form of DPI-SSL / MITM
