Connectivity gaps - firewall Meraki cloud traffic block
Gunter
Hello Meraki fans 🙂
I have a problem with connectivity status of my switches and APs. After some test I'm sure that this is related with the firewall policy I setup. At the end of my firewall policy I added "Explicit rule"
I added also rules which allow traffic to the Meraki dashboard (base on THIS topic):
After that my connectivity status look like this:
There is a lot of 1 minutes of disconnections
Yesterday I allow whole traffic to the Internet for testing purposes and Connectivity status look very good:
If any one know how to resolve this issue?
Thanks in advance
Gunter
WadeAlsup
I don't know for certain if they keep that article you have linked up to date (I would hope and imagine they would), but you can also check the Help>Firewall Info within your own dashboard to see the specifics and updated rules needed for proper communication. It's also linked from the article you posted.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
WadeAlsup
Gunter
Thank you for the link, I've just update my rules and I will check how the situation looks like after some time. I will share my test with you.
Gunter
I've configured firewall as was in your link and now everything is fine. Thank you for your support.
