Connection of several Non-Meraki VPN peer
Kevin_k78
Hello,I currently have a problem when I want to connect multiple non-peer Meraki.
I want to connect several MERAKI in VPN but the equipments are in different organization.
other MXs located in other organizations.
So I configure the tunnels in Non peers Meraki. When I connect one I have no problem but when I connect a second then the first one disconnects and the second connects. Is it possible to connect several Non peer meraki or not?
5 Replies 5
DarrenOC
Hey @Kevin_k78
There's no restriction on the qty of non-meraki VPN's you can have.  What's being logged in the event log?
https://documentation.meraki.com/MX/Site-to-site_VPN/Troubleshooting_Non-Meraki_Site-to-site_VPN_Pee....
Kevin_k78
Thank you for your reply. Here are the messages that I have:
msg: <remote-peer-3|1118> deleting IKE_SA remote-peer-3[1118] between
msg: <remote-peer-3|1118> closing CHILD_SA net-3-0{78} with SPIs cdec0598(inbound) (2604 bytes) c9313e1c(outbound) (5124 bytes) and TS
DarrenOC
What MX firmware are all the devices running?  Same across the board?  Are you using IKEV2?
Have you run a packet capture on your MX WAN interface to see whats happening?
Kevin_k78
The Firmware is the latest but my vpn using IKEV1. I don't see anything congruent when I take a capture .... The Meraki support can't find ...
Pavithran
IKEv1 supports communication between only two CIDR in a tunnel. Example : 10.1.10.0/24 can communicate to 10.2.10.0/24 but if other subnets wants to establish a tunnel with same peer subnet then the traffic gets dropped as IKEv1 doesn't support multiple CIDR communication.
