Connecting to a subnet through a VPN
alankevinr
Just browsing
Hi we have three different subnets,
192.168.1* Internal addresses
VPN once connected you get an IP address from this range 172.16.0.0/24
192.168.213*
10.2.0.* Azure
All internal LAN users can see the three different subnets..
If I dial in using a VPN i can't resolve to the 10.2.0 subnet. Do I set up a static route route or a source based default route?
Any help will be really appreciated.
6 REPLIES 6
Jwiley78
Re: Connecting to a subnet through a VPN
I think in Site 2 Site VPN you have to make the client VPN subnet part of the Site to Site VPN.  Check under VPN settings
OVERKILL
This.
Under Security and SD-WAN -> Site-to-Site VPN -> VPN Settings -> Local Networks
Ensure that the networks you want accessible over the VPN are selected.
alankevinr
Just browsing
Thank you i have already checked this and it hasnt worked.
The 10.2.0.* network is in azure
alankevinr
Just browsing
Hi I think the issue is the 10.2.0.* is in Azure, from Azure is connected into local sunbewt 192.168.219>*
Azure will need a return route for 172.16.0.0/24.
alankevinr
Just browsing
Thank you i have asked the MSP to add this route into Azure.
