Connecting a MG21E to MX68
rsage_voda
Is it permissible to connect an MG21 via one LAN port to the WAN 2 port on an MX68 and then connect the LAN port on the MG21 to one of the PoE ports 11 or 12 on the same MX68
Ryan_Miles
Meraki Employee All-Star
Yes, that works fine. I have it documented in this deck.
2 Replies 2
Ryan_Miles
Going sideways, you can see other ways of powering it at the bottom of this page:
https://meraki.cisco.com/product/cellular/external-antenna/mg21e/
