Connecting Non Meraki VPN
CashG
The company I work for was sold. As a temporary connection between our network and theirs can I add their VPN in the Non Meraki VPN section and then all they would have to do is add my Meraki HUB location? As long as there are no IP conflicts this should work right?
2 Replies 2
DarrenOC
Correct, you’re just creating a S2S vpn between two firewalls.
Also note this only creates a connection to just your site - and not to any other spokes that you have.  If they need access to the spokes then they will also need to build a VPN to each of your spokes.
