Configuring ethernet port link negotiatoin
IanHocking27
Hello.
I am trying to use "setup.meraki.com" to configure the ethernet port negotiation setting on an MX64.
Its says the default password is the serial number of the MX.
Neither the serial number or my Meraki dashboard userid/password work.
any ideas?
many thanks
Ian H
On the network-wilde > general  dashboard page you can see if a local status page password is set.  Username  admin
CptnCrnch
Try using http://mx.meraki.com with the device serial (upper case letters and dashes) as username without any password.
IanHocking27
thank you!
