Is it possible to do this type of l NAT on a Meraki MX , like an ASA ? e.g.
nat (inside,outside) source static PC NAT_PC destination static RemotePC-VPN RemotePC-VPN
Solved! Go to solution.
Looks like it (Meraki MX to Meraki MX) can be enable via Meraki Support
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_Site-to-site_VPN_Translation
Thanks everyone for your responses
You want an IP address NATed but only for client VPN users?
I don't think so.
Repeat after me: MX is not ASA / Firepower. MX is not ASA / Firepower. MX is not ASA / Firepower
@CptnCrnch wrote:Repeat after me: MX is not ASA / Firepower. MX is not ASA / Firepower. MX is not ASA / Firepower
Amen! 😉
But be aware that this feature will not provide the functionality you were asking for. It's only for Auto-VPN and will translate a whole local subnet. Well, the last point could perhaps be solved with a static host-route on the MX.
