Compatible copper mods for MX250
cant find a spec sheet anywhere listing the copper mods???
Solved! Go to solution.
This PDF contains the list of all compatible SFP/SFP+.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
If you want 10Gbe SFP+ copper check out the TwinAx cables:
MA-CBL-TA-1M
MA-CBL-TA-3M
If you just want plain Gigabit then:
MA-SFP-1GB-TX
The only certified part I am aware of is the MA-SFP-1GB-TX but a Cisco GLC-T works just fine... There are no 10GbE Cu certified parts
