Colors on the map and status
MikaR
Am I the only one that color codes of mx devices (we mainly use mx68cw) are bit annoying. We have network of 165 SD-WAN devices, and little over 100 of them is using cellular connection (4G) as the primary/only connection to internet. They work quite fine, but all these sites are marked 'yellow' color (instead of green) on the map and as their current health status. I understand that if someone use fixed WAN connection and cellular is secondary/backup connection, this would be the desired color, but in our case where the scenario is different, the color codes are confusing. I Would like to see configuration option where I could select which is the primary connection, and then if it drops to secondary (or no connection), color would be yellow (or red in no connection situation).
2 Replies 2
Dylan-T
Hi MikaR,
While it is not currently possible to configure the coloring of the device status icons, I do see where some customers would find value in this, like the example you gave.
I recommend and encourage you to use the "Make a wish" button at the bottom right corner of the dashboard. These requests go directly to the product management teams.
I also wish there was a way to "acknowledge" the status and reset it to "green".
For example, a branch is being refitted over a month, and you know it is going to be down.  Acknowledge the down so you can ignore it.
