Hi There,
Anyone encountered error below while deploying Umbrella via Cloud on-ramp?
I used the Management API(Not network one) for sure, Any other place i shall check for this error? Thanks
Solved! Go to solution.
You "only" have DNS Advantage, which is Umbrellas DNS based security solution.
To be able to use Cloud On-Ramp and all of its functionality, you'd need at least the SIG Essentials license for Umbrella in place.
Do you have SIG licensing on the Umbrella dashboard? Per the requirements listed here: https://documentation.meraki.com/MX/Meraki_Umbrella_SDWAN_Connector/Deployment_Guide#Requirements
Yes, please see below
Thanks, i think that should be the cause of the issue.
