Clients Blocked
Mule
Clients Blocked
Hello all,
I recently blocked afew suspicious users on our network. I later unblocked some of them later. However those machines cannot access the internet/LAN even after the reversal. The status is showing normal/whitelisted but no access to the network resources. Please help
Mule
The solution was actually deleting the clients and then after they reconnected to the network, all was OK
10 Replies 10
kYutobi
Did you try re-entering the MAC address and assigning a policy through the "Add client" button just to see if that works?
Enthusiast
Mule
We use the Meraki (MX60W) as a firewall and just an ordinary switch to connect the clients. Therefore is no option adding clients, once they connect to the Ethernet or wifi they are on the network.
AjitKumar
Hi @Mule
Could you please verify the "MAC Address" of the "Whitelisted" machine?
Is it correctly Identified on the Dashboard?
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Mule
I checked, the dashboard mac and the one one the computer are matching.
Are you sure you unblocked the right devices?
Try creating a dummy group policy and applying it to the device and see what impact that has.  For exmaple, we have a dummy policy we use for testing called "Block Gambling" that uses content filtering to block gambling.
If the dummy policy applies they go back and whitelist it.  If it doesn't apply - are you sure you are doing it to the right device?
Are you using a recent firmware version?
Mule
Yes, even though I am not seeing the meraki access denied splash screen but I am getting n63.network-auth.com err too many redirects
Mule
FleuxRas
Hi Mr. Mule,
Can you teach me how to delete the clients? I have similar case.
Mule
Just delete the users, it was not working when we changed status from blocked to normal or whitelisting. So we just deleted those users and then they reconnected on the network as if they are new users. Good luck
HungNgHuuKhanh
Just browsing
Hi Mr.Mule,
I got issue "Blocked list is restricted to 3000 devices."
But I cannot find the delete option in my dashboard.
can you teach me how to delete clients, pls
