Search instead for
Client vpn dhcp
Client vpn dhcp
Is it possible to do dhcp on client vpn subnet?
Accepted Solutions
Re: Client vpn dhcp
No.
The address are dynamically allocated from the pool you specify, and you can configure DNS and WINs servers to use, but that is it.
7 REPLIES 7
Re: Client vpn dhcp
No.
Re: Client vpn dhcp
Thanks. When you say pool, you mean the host ranges from the VPN subnet mask?
Im using 192.168.50.0 /24
Re: Client vpn dhcp
From this address range:
Re: Client vpn dhcp
Ok, so my Client VPN subnet is 192.168.50.0 /24
So I would get 254 hosts with ranges 192.168.50.1 - 192.168.50.254
Re: Client vpn dhcp
Also speaking of VPN.  Right now, I have my company DNS servers for VPN.  Is it a good idea to add public DNS such as 8.8.8.8?
Re: Client vpn dhcp
If you are using active directory you should only be using the internal AD controllers for DNS.
Re: Client vpn dhcp
Correct.
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
