Client connect and disconnect about 100-200 times a day (Synology Nas)
ManolisFr
Hello
Basically we have no problems with disconnectionson our local network. Because of server delays last weeks (maybe sql issue) i enabled the alerts for all the workstations we have about the connections and disconnections from Lan
We have a Synology Nas and it working without problems and making automatically backups every day from all the workstations (monday to friday). But every 5-10 minutes i receive a mail that the Nas disconnected ..and after some second connected again. I had enable also mail alerts on Nas but it seems that has no issue.
Maybe it's a bug from meraki? I don't know. Does anyone has the same issue?
DarrenOC
Sounds like the device is going into hibernation mode:
https://kb.synology.com/en-global/DSM/tutorial/What_is_the_difference_between_HDD_Hibernation_System...
3 REPLIES 3
DarrenOC
Hello
Thanks, i will check it tomorrow but probably you are totally right because during backup procedures from some machines and the server,  between 10:00pm and 02:00 we have no alerts..
@ManolisFr
Was hibernation the answer?
