Client Visibility on MX250
Hello Meraki Community,
We have successfully cut over to a Meraki infrastructure and I was wondering if it is possible to see individual client hits in real time?  For example, if I want to see if a particular user is getting caught up in a rule, where can see it live?  We previously had an ASA 5520 and that was able to provide the visibility.  Any suggestions?  Thanks!
Accepted Solutions
Re: Client Visibility on MX250
3 REPLIES 3
You can't see real time in the dashboard.
@ww is correct, you would need to use something like syslog to see this.
Thank you for the responses!  That seems like a logical way to go.
