Client VPN two profiles
mmp
Is it possible to set up two separate IPSec settings for the client VPN. I want to allow a specific user outside my organization access to only one server on the corporate network. I do not want to share my existing VPN settings which used AD authentication
Thanks,
Moises
4 REPLIES 4
Unfortunately not, but you can configure L2TP and at the same time Any connect.
Frank-NL
What you can do, although not a very pretty construction:
1. Create an account for the external user in your AD
2. Create a Meraki group policy with firewall rules as required for this user
3. Once the user has connected the first time, apply the policy to the client from the client page
This works best when the default network firewall does not allow any traffic from client VPN subnet, and then this way you will be able to authorize them after first time connect.
I will try this and let you know
Thanks,
Moises
