Client VPN to Non-Meraki VPN peers routing
PaulinBeer
Hi... I have read loads on this but nothing that seemed clear cut in its resolution.
So we have a local subnet of 192.168.3.0/24 with a Non-Meraki VPN to 172.29.40.0/25, this is working and pings to the Non-Meraki VPN peers respond.
We have a client vpn subnet on 192.168.7.0/24 and can ping devices on the local 192.168.3.0/24 network but cant ping anything on the 172.29.40.0/25 network. My question is what needs to be done to allow traffic from the client vpn 192.168.7.0/24 through the Non-Meraki VPN to 172.29.40.0/25?
Does the other end of the non meraki vpn has a route to 192.168.7.0/24?
7 REPLIES 7
Jwiley78
Under Site 2 Site config tab make sure your client VPN subnet is allowed through Site 2 Site tunnel.
Hi, if you mean to enable it below then I have already enabled it.
Jwiley78
Yeah, that's what I was referring to.  I've missed that step a few times in the past.  If that's set and no ACLs are blocking then I would reach out to support.  They can help with packet captures to assist.
PaulinBeer
I suspect not, will that be needed?
Yeszz
PaulinBeer
Hi, that solved it... so simple.
Thanks for you help.
