Client VPN prevent from connecting from certain countries
knightrider
We  want the  Client VPN prevent from connecting from certain countries, We have firewall Layer 7 rule "Deny Traffic not to/ from USA, Canada, UK" ,but this rule did not helped , we found user able to connect from India.
WE open the t case with meraki support , they  reply "Layer 7 rules do not apply to inbound Client VPN connections"
Is any one have idea how we can implement client vpn  prevent from connecting from certain countries.
I can't think of any way to do this.
Going sideways, if you want to improve your security posture, consider using MFA with Client VPN, such as Cisco Duo.
https://duo.com/docs/meraki-radius
6 Replies 6
Inderdeep
@knightrider : You can do that as shown below using Layer 7 rules
www.thenetworkdna.com
knightrider
Yes this is what we have L7 rule in place, but user still able to connect .
Inderdeep
What license you have on the MX ?
knightrider
we have advanced security license  for MX100
knightrider
Thanks this way we think off to go with
