I am having an odd issue with a specific subnet over the client VPN this subnet is in the local subnets, which in the meraki vpn documentation states the client VPN can access those automatically. I can access every other subnet but this one. The client VPN subnet is 10.1.2.0/24 the subnet it cannot access is 192.168.10.0/24 which is a voice network, I am trying to setup softphones for some teleworkers and have had zero luck with this. Makes no sense as I have nothing blocking accessing that subnet, pcap's haven't helped much either. Any ideas?
Solved! Go to Solution.
I fixed it somehow send all traffic over the vpn was not enabled. That subnet now works. Thanks!
Have you added a static route and selected "In VPN?"
Why would you need to do that if it is in the local subnets on the MX. Even trying that I get "Static lan route subnets cannot be contained by (or be equal to) a client VPN subnet."
If this was a solution, it would be for the VOIP subnet. If the VOIP is also local then yeah, you probably don't need it. At the headend have you ran a pcap on the internet and client_vpn interfaces?
I have ran pcaps on all interfaces.
Are you using 192.168.10.0/24 as the local "home" subnet - if so then it won't work.
Has the phone system ever needed to communicate outside of its local subnet before? If not then I bet it has a mis-configured subnet mask or default gateway.
The next most likely solution is the phone system is configure to not allow connections from 192.168.10.0/24.
I was into this issue and tired to tinker around to check if its possible but couldnt get it done. Now that i have seen the way you did it, thanks guys
with
regards
