Client VPN Utilizing RADIUS Failing on 2019 Servers After Recently Patching
dromios
We have a client that is using RADIUS authentication for client VPN.  It's been working fine up until the servers were patched.  Has anyone run into this issue, and if so, come up with a resolution?
Regards,
Doug
12 REPLIES 12
CptnCrnch
What kind of RADIUS servers are being used and which version were they upgraded to?
We have been using the Windows Server 2019 Standard built-in NPS for RADIUS. Nothing was upgraded, but Windows Updates were run and the servers rebooted before this stopped happening. I followed the documentation outlined here:
https://documentation.meraki.com/MX/Client_VPN/Configuring_RADIUS_Authentication_with_Client_VPN
It worked like a charm out of the box. I tried removing the Calling Station ID per the article, as it said some RADIUS servers wouldn't like it, but it didn't make any difference. I'm being prompted for the username and password but when I connect it get's stuck on "Verifying your sign in information" and it eventually says "The remote connection was denied because the user name and password combination you provided is not recognized, or the selected authentication protocol is no permitted on the remote access server."
CptnCrnch
Is the Dial-In permission set for the specific users?
The dial-in properties are set to use NPS.
Nash
@dromios What errors are you seeing on the NPS server log?
dromios
I was looking at the text file auditing but just found more information in event viewer by enabling information events:
I'm getting alerts that say "Network Policy Server discarded request for a user". Followed by:
Authentication Details:
Connection Request Policy Name: Meraki VPN
Network Policy Name: Meraki Client VPN
Authentication Provider: Windows
Authentication Server: DC01.xxx.local
Authentication Type: PAP
EAP Type: -
Account Session Identifier: -
Reason Code: 9
Reason: The request was discarded by a third-party extension DLL file.
That's something new to go on.
We are having a similar issue in my environment. Patched 2019 NPS servers and now Meraki Client VPN is broken.
Has anyone found a resolution to the problem in this thread? Curious to see what is similar to my issue.
dromios
I forgot to mark this as completed.  Another round of patches actually resolved the issue for me.  If you don't have any more options I would put it on any server you have below 2019, that's what I did temporarily at least.  It's not an ideal fix but when in a pinch it helps.
Thanks for the reply my friend. We will try that also!
dromios
If you right click on nps you can export the config and import it quickly.  Should work from 2019 to any other 2019/2016 server, not sure about 2012 or 2012 r2.
Nash
My systems people have recently successfully ported from 2012 r2 to 2016 and 2019, using this method. You're talking about the one that creates a big ol XML dump, right?
dromios
That's correct.  Good to know it works all the way back to 2012 and vice versa!
