Client VPN + RADIUS: IP filtering not working
hi,
I followed the guide here
https://documentation.meraki.com/MX/Client_VPN/Configuring_RADIUS_Authentication_with_Client_VPN
and have successfully setup RADIUS authentication for client vpn users. However, this guide gives full network access to all VPN clients. I would like to limit this to a single server, so I created an IP filter on the NAP Policy > Settings tab
IPv4, input filter, permit only, destination address = 192.168.100.40, mask = 255.255.255.255
IPv4, output filter, permit only, destination address = 192.168.100.40, mask = 255.255.255.255
I apply these changes and login as a VPN client. However, I am still able to access any network resource. I am not limited to just the server above.
I know I can create FW rules on the MX itself, but those rules cover the entire client VPN subnet. The plan is to eventually have different fine-grained policies for different user groups.
What am I missing?
Accepted Solutions
Re: Client VPN + RADIUS: IP filtering not working
Meraki client VPN functionality when used with RADIUS does not support ACLs or Filter-Id (for applying group policy).  More specifically it does not support any way to restrict client VPN user access.  Zero.
10 REPLIES 10
if i read correctly the nap policy is client based. so the vpn client needs to understand this. what client do you use?
Thanks for the reply.
I'm using the Windows 10 built-in client, as documented here
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_OS_Configuration#Windows_10
sounds like win10 is not supported:
https://en.m.wikipedia.org/wiki/Network_Access_Protection
Re your other comment about using L3 firewall, yes, I could use that but it affects the entire VPN subnet. Using that method it is not possible to filter by user/group.
The only other way to do it seems to be using AD authentication instead of RADIUS. This document covers that setup, so I may investigate that option if I can't get NPS working.
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Configuring_Active_Direc...
Indeed, that is a limitation of doing it that way.
However I'm afraid your idea may not work either. See this note:
Note: At this time, the MX does not support mapping group policies via Active Directory for users connecting through the Client VPN.
🙄 What a pain.
I can't create a 2nd client VPN profile, RADIUS won't work, AD authentication won't work. So I'm out of options on the Meraki/MX side?
Urgh.
That link refers to NAP (Network Access Protection).
I'm using NPS (Network Policy Server), so does that apply to NPS too...?
NAP is deprecated by Microsoft and does not work in newer OSs.  Don't deploy this technology.  If you can get it working because you have old OSs on your servers and clients you will loose the functionality as soon as you upgrade them.
