Client VPN - Keep alive
Patrik73
We are using Windows builtin VPN-connection for Client VPN to Meraki.
Are there any settings / function for keep alive or reconnect in case the connection drops?
Thanks!
Unfortunately not, there is no timeout option. The session will only terminate once the user clicks disconnect or reconnect it.
If you want more advanced options, maybe you should use Anyconnect.
Patrik73
Thanks for reply!
I was afraid that this was the case. 😞
I think what you ask asking is - if the connection drops can you get it to reconnect automatically?
The answer is no for Windows client VPN.  As @alemabrahao mentions, you need something more advanced like Cisco AnyConnect to get that functionality.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance
Patrik73
Thank you for clarifying that.
