Client VPN Issue
Eyad2411
Client VPN Issue
I Have an issue over the MXs in different organizations where I'm unable to connect to the Client VPN.
the Massage showing in my Computer is " The L2TP connection attempt failed because the security layer encountered a processing error during initial negotiations with the remote computer"
where in the Event Log it is showing the following Massage
Non-Meraki / Client VPN negotiation     msg: FIPS mode disabled
Please Note that pre-shared Key along with the Username and Password is 100% same as configured over the MX
Inderdeep
@Eyad2411 : Check this out
https://documentation.meraki.com/MX/Client_VPN/Troubleshooting_Client_VPN#Windows_Error_789
Regards/Inder
www.thenetworkdna.com
2 REPLIES 2
Inderdeep
Regards/Inder
Hey thanks man! This section was the fix for me:
