Client VPN Group Policy deployment with shared secret
Hi all,
Has anyone figured a way of incorporating the VPN shared secret into a GPO containing the VPN settings to be deployed to users
thanks
james
Accepted Solutions
Re: Client VPN Group Policy deployment with shared secret
Hi @WadeAlsup
i have found a Powershell script we can run on startup:
Add-VpnConnection -AllUserConnection -Name "(vpn_name)" -ServerAddress "(vpn_address)" -TunnelType L2tp -EncryptionLevel Optional -L2tpPsk "(vpn_sharedsecret)" -AuthenticationMethod Pap -Force
James
3 REPLIES 3
Hi @jameshottinger
I have a link to a Spiceworks article saved in my notes from when I was trying to do the same thing. I never could get a GPO that would include the pre-shared key...but I was able to use the CMAK (Connection Manager Administration Kit) and create a configuration that works for our scenario. It may be worth looking into.
https://community.spiceworks.com/topic/417332-gpo-to-configure-l2tp-vpn
https://www.windows-server-2012-r2.com/create-a-connection-profile-with-the-cmak-wizard.html
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
Hi @WadeAlsup
James
Nice!!!
