Cleint VPN - IPsec and AnyConnect - Use same subnet?
ktv-meraki
Good Morning,
This should be a straight forward question.  We have been using Client VPN with IPsec Settings configured and users are using Windows Always On VPN and is using its own subnet.  We have a desire to get AnyConnect working while our users still use the Always On VPN.  When I go to enable AnyConnect, it asks for a subnet.  Do i have to create a new subnet or can I use the same subnet our traditional VPN has been using?
Thanks!
KarstenI
No, the subnets have to be different.
rhamersley
We use Always on VPN and sometimes having the Meraki Client VPN option as a back up if you need to uninstall the Cisco Secure Client and have your user log into your Meraki Client VPN to push out any updates needed for that workstation.
Yes you have to have 1 subnet for the Meraki VPN and a different subnet for the Cisco AnyConnect configuration.
ktv-meraki
Thanks for the input.  I appreciate it very much.
