Clear DHCP leases - Z3C firmware 19.1.3
252_Masked_Nett
Hello Good Folks,
Anyone able to clear DHCP leases with any workarounds? Already tried the below (independently), allowing the config to update after saving:
  • Cycling DHCP server
  • Reserving entire IP space
  • Extending existing reserved range
None worked for me. Anyone have add'l ideas besides rebooting.
#dhcp #clear_dhcp
KH
Meraki Employee All-Star
Hey @252_Masked_Nett
If you are referring to the Z3 itself ,a factory reset will clear leases off of the device. Otherwise, you can edit the DHCP scope from a /24 to a /23 for example, just ensure that the config changes were pushed to the device and the Z3 is up to date before changing it back, typically waiting 5 minutes between changes should suffice.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
5 Replies 5
KH
252_Masked_Nett
Yes, I'm referring to the Z3C as the DHCP server.
Reboot the Z3
Alas that doesn't clear the DHCP leases.  I wish it did.
The way I do it is to turn off DHCP for a little bit, and then turn it on again.
