If you are not aware of your license, then it is very likely that you run the stable version. v15 is Beta and typically only used when a specific function is needed.
You see the versions on Security-Appliance -> Appliance status.
For the license, there are Enterprise, Advanced Security and SD-WAN. You need at least Advanced Security to integrate Umbrella into MX. You see your license under Organisation -> License Info.
I would go a phased approach:
1) Buy the Umbrella DNS Essentials license for the amount of users in your organisation.
2) Enroll two Umbrella VMs in your main office and configure them in regards to the Umbrella Documentation. When finished, all users in the Headquarter are protected.
3) Do you have Meraki APs? Then the next step is to integrate Umbrella into your SSID.
4) Now some more months are gone and you can decide how to go on for your branches. Either with dedicated Umbrella VMs or you decide that it is safe enough to go to MX15 and activate the native integration.
