Inside of the Meraki platform, I don't believe there is a way to do this yet. I use Layer 7 to block certain countries and there isn't even a way for me to make an exception to that if I want to whitelist a few URLs. So as @PhilipDAth pointed out, your solution will likely be outside of the Meraki platform.
