Cellular failover MX67C
Havey
Does the MX67C (in Canada with a Cisco tested cell carrier) require a static ip in order to failover the VPN?
Aaron_Wilson
Nope. I have a DHCP assigned private IP (NAT'd) on mine right now. If I yank the wire it fails over to cellular and the AutoVPN reconnects back to the hub.
1 REPLY 1
Aaron_Wilson
