Cannot print through wireless PC
DUITMAN
Greetings,
I have installed a Cisco Meraki 67 into our network. Our office has 2 printers we have a HP printer and a Brother Printer. We have around 5 users in the office. 2 of us can print off one printer which is the HP printer. Only 2 users are able to print off the brother printer and the HP. There is only one user who cannot use both printers.
The one user is connected via hardwire. The user tries to print on the hp printer but all they get is a error and it's stuck on queue. I tried the bonjour forwarding rule but it does not work either.
If anyone can help it will be greatly appreciated
What version are you running?
 I had the same issue with version 18.x, and it just backed to work when I downgraded it.
I suggest you open a support case.
DUITMAN
I'm using the
Mx 18.107
Hopefully the version isn't the problem. I'll try to see if i downgrade if it would work because this is a problem that just recently started.
It was the same for me, I updated it and for almost a week it worked without problems, and suddenly it stopped.
