Can we generate configuration?
Iamyour_Joy33
Hello all,
Can anyone let me know we can generate configuration between Spoke and Hub ?
Thanks,
Joy
Malwina
Hi! Just to clarify, are you asking about a specific setup or configuration between Spoke and Hub? Like, are you looking into VPN settings, routing, or something else?
In the meantime, here's a link to the Cisco Meraki docs that might be useful for setting up Spoke and Hub configurations:
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Settings
6 Replies 6
Malwina
Iamyour_Joy33
Hi, thanks for document. May i know is there any ways to show configuration like Cisco router " show running-config"?
There is not.
Iamyour_Joy33
Hi Philip,
So this is only configuration we can check?
For Meraki AutoVPN, yes.
Iamyour_Joy33
Thank you. I was looking for it so that i can do configuration hardening so easily.
