Has anyone else experienced this?
Example MX is set to VLANs and has one or more VLANs defined. (May also happen with Single LANs I just don't ever set them up that way)
Static Routes exist pointing other subnets across that VLAN to another layer 3 device.
I make sure all dependencies for the statically routed subnets are gone/disabled (DHCP, firewall rules, etc)
I try to change the VLAN on the MX and the static routes at the same time.
MX gives error saying the static route has an invalid next hop and lists the old next hop IP.
This used to work, but I've seen the error multiple times over the past few months. It seems the order of operations or validation criteria on the backend have changed.
I intend to open a case but was just wondering if anyone else has noticed. It's just a few extra steps but deleting also loses the DHCP info that I would usually just edit instead of having to recreate.
And before anyone asks Templates are not an option for us.
