Can't See the Uplink Traffic and Live Data
Reahuo
Hello team,
Is there any update on the Meraki Dashboard, now I can't the Uplink Traffic and Live Data.
Thank you.
DarrenOC
Possible backend issue maybe?  Just checked a bunch of Orgs and I’m getting the same.  Can see historical data but nothing live.
7 Replies 7
DarrenOC
Uplink missing on n199 as well, but live firewall log still works
AaronS
Seeing same thing this morning on n732.
jimmyt234
Getting the same across multiple orgs and shards.
jamesht
how is this solved it still shows no live data
As @DarrenOC said, it is a back end glitch and should solve itself as it did for me.  What shard are you on?
Kevin_R
Hello @jamesht,
At this time the issue with live data not populating on the MX uplink tab should be resolved. If you (or anyone else) are still experiencing issues with the MX uplink live data graph not showing any data, I would encourage you to open a support ticket to look into the issue further. Or if a ticket is already open and are still seeing problems with the live data graph, please update the ticket so that support can update our Engineering team.
