Upgraded a machine to MacOS 13 Official Release and now the machine will not connect to AWS Hub sites over VPN.
All other traffic seems to work fine.
Works on network.
Any thoughts?
What specifically is the error? Throughout all the Ventura betas the native L2TP VPN client would break (when previously working) and not allow config through the settings page. The fix is to create a VPN config using Apple Configurator or push a VPN config from a MDM like Meraki SM or another platform.
The Apple Configurator option is pretty easy and the app is free.
Just get this now. Everything worked on 12.6 and the previous versions. We use Sentry authentication on machines and I re-pushed all profiles made in Apple Business Manager to the machine...
Are you talking about Client VPN?
look at this information:
The instructions below are tested on Mac OS 10.7.3 (Lion).
Currently, only the following authentication mechanisms are supported:
When using Meraki-hosted authentication, the VPN account/username setting on client devices (e.g. PC or Mac) is the user email address entered in the dashboard.
Open System Preferences > Network from the Mac applications menu. Click the "+" button to create a new service, select VPN as the interface type, and choose L2TP over IPsec from the pull-down menu.
The VPN connectivity will not be established if you don't enable the Send all traffic over VPN connection option.
All of that is pushed via profiles from Apple Business Manager and Meraki using sentry (not user configurable). Worked the day before and stopped working the day of the update to MacOS 13...
It's quite possible there's a change in Ventura that has broken VPN.
As @Ryan_Miles mentioned, the beta had lots of issues with VPN breaking.
Additionally a heap of active monitoring security agents and EDR software stopped working too.
Worth opening a case with Meraki support. If they're seeing it as a widespread issue there'll be more traction on getting it diagnosed and resolved
Yeah, I submitted a case just now... We'll see where that leads...
Hello
did you find a solution? I'm in the same situation.
Best Regards
