Can a MX68 can split into two VLANS - One on the VPN side and the other without the VPN
MDInformatique
I have a customer that whant to have 2 VLANS, 1 that is connected via a VPN tunnel and the other vlan without the VPN.
Can you confirm that we can do that with meraki?
UPDATE :
I took a look at the VPN tab on a meraki MX and I saw that this was doable as we can select each VLAN VPN ON or OFF.
1 Reply 1
KRobert
Yes,
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Addressing_and_VLANs
In Routing->Subnets: In VPN: Determines whether the MX advertises this VLAN to site-to-site VPN peers.
CMNO, CCNA R+S
